Hi to all,
In Flare Knockout drum, no valid liquid case exist and i consider liquid flow as 2 wt % of maximum gas flow.
Is this good practice to size horizontal KOD or Vertical KOD?
Posted 01 November 2019 - 03:39 AM
Hi to all,
Posted 08 November 2019 - 05:28 AM Best Answer
There would be no preference of one type or the other for KOD so far as the gas carries no liquid droplets.
The KO efficiency may depends more on the particle size than the total content of liquid carrying over.
Horizontal type is preferred for the longer residence time for finer liquid droplets.
Sizing formula, I remember, seems to be developed usually based on >98% removal of more than 300 micron droplets.
Steam Drum SizingStarted by Guest_nastaran_* , 01 Dec 2025 |
Flare Header Reverse FlowStarted by Guest_Ahmadhamzahperta_* , 04 Apr 2025 |
Lng Boil Off Gas Compressor Suction DrumStarted by Guest_Lyne_* , 04 Jun 2025 |
