Process Simulation - Allowable Error?
#1 alextor
alextor
  • 12 posts
Posted 29 November 2019 - 12:10 AM
Plant data and relevant process simulation results always have a difference in values (temperature, pressure, concentration).
The smaller this difference (error - %), the more accurate the model.
But what error values (average and maximum) are allowable in practice? 1%, 5%, 10%?
In what documentation is a allowable error indicated?
#2 Bobby Strain
Posted 29 November 2019 - 05:41 PM
There is no general answer to your question. If you are more specific, you may get some advice. Often errors are due to the wrong model.
#3 alextor
alextor
  • 12 posts
Posted 04 December 2019 - 01:37 AM
Simulation petroleum refining unit. Full material balance includes columns, heat exchangers, pumps, vessel, reactors....
#4 breizh
  • 7,027 posts
Posted 04 December 2019 - 01:50 AM
hi,
Make you sure fields data are properly monitored with calibrated sensors .
good luck
Edited by breizh, 04 December 2019 - 06:15 AM.
#5 gegio1960
gegio1960
  • 518 posts
Posted 04 December 2019 - 12:22 PM
in other words...you will have errors both in simulations and in field data...often in different directions :-)
the error is highly dependant by the kind of characterization (eg distillation curves vs chemical compositions) of the feedstocks and the kind of process (eg a CDU/VDU vs a mature licensed process).
moreover, the magnitude of possible errors depends by the observed parameters (eg an operating temperature vs a cetane number).
nowadays the design margins, that should allow to compensate the uncertainties, are generally limited to 10% and only foreseen for the single items, without the previously adopted capacity margins on units.
good luck!
