Hi to all,
how to find vapor pressure of the stream (crude mixture from separator oil out) in hysys?
Posted 17 December 2019 - 04:25 AM
Hi to all,
Posted 18 December 2019 - 07:20 AM
Hi
You can insert vapor fraction = 0 and specify required temperature , so calculated pressure by hysys is vapor pressure.
Posted 24 December 2019 - 12:38 AM
Hi
Or input vapor pressure as 0.01
Pressure BuildupStarted by Guest_Yankee_* , 31 Mar 2026 |
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
