Flow Compensation From Temperature Measurement
flow compensation;
#1 Movers
Movers
  • 71 posts
Posted 25 February 2020 - 03:23 AM
Hello.
Are there any restrictions to use one temperature measurement and one pressure measurement to flow compensation of few streams? How much streams flow can be compensated by this way?
I see one risk - in case of failure this measurements. But could it be solved by set system to take the last known correct value?
Edited by Movers, 25 February 2020 - 03:25 AM.
#2 thorium90
thorium90
  • 1,073 posts
Posted 28 February 2020 - 09:35 AM
If a more accurate flow measurement is desired, might I suggest to use a flow meter that can measure the flow accurately without need temperature or pressure compensation?
#3 breizh
  • 7,062 posts
Posted 29 February 2020 - 07:16 AM
Provide more information about the fluid and temperature /pressure set points if you want a meaningful answer.
My thoughts
