Insulation Of Fired Heater Stacks
insulation heater stack fire heater environment emissions
#1 Sherif Morsi
Sherif Morsi
  • 173 posts
Posted 05 May 2020 - 08:39 AM
Hi All,
A fired heater does not have an insulated stack (either outside or inside using refractory). Corrosive compounds like sulfur usually condense and fall inside the fire box on the heater floor. A decision was made to insulated this stack as part of an asset integrity program.
My question is: Would insulating the stack affect the flue gas composition and environment emissions?
Sherif
#2 Movers
Movers
  • 71 posts
Posted 07 May 2020 - 02:01 PM
Hi.
If stack is not tight some amount of trump air is getting inside. After isolation of the stack, the amount of trump air should be lower and oxygen content in flue gas should be also lower.
Best Regards
#3 Sherif Morsi
Sherif Morsi
  • 173 posts
Posted 15 May 2020 - 10:21 AM
Thanks Movers
