Hello.
Do you know which parameters have impact on speed of steam cracker radiant coils carburization?
Is it possible that oxygen level in the flue gas is one of such parameters?
Edited by Movers, 26 June 2020 - 07:32 AM.
Posted 26 June 2020 - 07:31 AM
Hello.
Posted 30 August 2024 - 02:04 AM
Hi Movers,
my answer may be a little late, but might be useful for others.
Carburization occurs because during the high temperature operation carbon from the hydrocarbon feedstock can diffuse into the wall and form brittle carbides on grain boundaries. Carborization predominantly occurs on the feedstock (inner) side of the tube.
Factors affecting:
Sincerely,
Tamás
Edited by Tdha, 30 August 2024 - 02:07 AM.
Steam Carrying Liquid From The Sour Water Stripping TowerStarted by Guest_kaidlut_* , 12 Sep 2024 |
Short Path Distillation Rotor SpeedStarted by Guest_MEC_* , 11 May 2023 |
