3
Aspen Plus Calculator Block
#1 chetanhm2
chetanhm2
  • 163 posts
Posted 02 July 2020 - 11:41 AM
Dear Sir,
How to add calculator blcok varibale in sensitivity study feature in ASPEN PLUS? I am running sensitivity study in aspen plus but I am  not able to add calculator block variable in sensitivity study setup here
Best Regards,
Chetan Chavan
#2 ChinmoyBasak
ChinmoyBasak
  • 38 posts
Posted 05 July 2020 - 06:50 PM
I don't know the use case but will Aspen Simulation workbook(ASW) may help in your case.
Though it breaks the link with Excel but found useful for my case.
#3 xXSpecialsoulXx
xXSpecialsoulXx
  • 4 posts
Posted 27 July 2020 - 01:23 PM
can you explain more about your problem , if  you run the sensitivity and you choose in options tab, and then then you select reset streams and block results , every time you run a new step the whole simulation will be restarted and run from 0 with the new parameters , this option it will take you more time but its works very well for me , tellme if this helps you
