I have to size line system, firewater system. I have several questions. I have default sizing datasheet. 1)-do we add valve, fittings length to the pipe length? Do we add hydrant lenght, pipe branch length to the pipe length? In datasheet i have special fitting sections, so i ll add valves there for pressure drop. But should i add the valves length to the total length?2) - I have excell datasheet, and there i can only calculate every line individually. How can i size whole system?how to interconnect them, please help.
Line Sizing (Hydraulics)
Started by Lorean, Jul 14 2020 01:53 PM
sizing(hydraulics) piping process engineering calculation
No replies to this topic
Posted 14 July 2020 - 01:53 PM
Sizing Two-Phase And Three-Phase SeparatorsStarted by Guest_guoyinyanliner_* , 03 Sep 2026 |
How To Size A Presure Equalization Line For A 10" Pipeline ValveStarted by Guest_Rerrizftt_* , 14 Jul 2026 |
Sizing Fire Case Relief Valve Installed Below Liquid LevelStarted by Guest_processrock_* , 14 Apr 2026 |
