Graphite Heat Exchanger
9 replies to this topic
#1 stelu85
stelu85
  • 17 posts
Posted 03 August 2020 - 02:02 PM
Dear all,
as first approach i've been proposed to use a graphic exchanger as condenser of reaction vapours containing:
H2SO4
CH2Cl2
H2O
HCl
cleary is a good choice, but i'm looking for what could be the disadvantages of a normal shell & tube heat exchanger.
The previous one was made of Alloy 8020
regards
  • 6,925 posts
Posted 03 August 2020 - 09:57 PM
For reference : http://www.deltathx....eat-exchangers/
why do you want to replace your existing HX and change the material ?
Graphite HX should be cheaper ....you need to find a reliable manufacturer of graphite HX  .
You may consider tantalum HX
https://www.alfalava...-ppi00578en.pdf
my 2 cents
Edited by breizh, 03 August 2020 - 10:14 PM.
#3 stelu85
stelu85
  • 17 posts
Posted 04 August 2020 - 07:40 AM
Hi Breizh,
thatnks for your tips. Cannot find any disadvantages on graphite HX.
Both AISI 316L and Alloy 8020 had corrosion problems, therefore we would like to solve this issue.
Probably the best solution is the tantalum you proposed. I will take it into account, thanks
regards
#4 TheChemEng
TheChemEng
  • 47 posts
Posted 05 August 2020 - 04:24 PM
We use graphite vapour condensers as standard at our facility and they are robust. We have cracked a couple over the years though which were down to poor maintenance work - over tightened bolts i believe.
#5 breizh
  • 6,925 posts
Posted 05 August 2020 - 08:42 PM
To add to my previous post , a brochure from Mersen :
https://www.mersen.c...ocks-mersen.pdf
#6 stelu85
stelu85
  • 17 posts
Posted 06 August 2020 - 02:35 AM
really thanks both of you.
Andy, would you suggest the condenser typology you have? Alfa Laval suggests even graphite plate heat exchangers for this application.
#7 MikeCH
MikeCH
  • 4 posts
Posted 10 August 2020 - 05:46 AM   Best Answer
Dear all,
H2SO4
CH2Cl2
H2O
HCl
regards
Graphite heat exchangers are more fragile. Too much mechanical forces from the connected pipework will damage your condenser. Proper specified bellows are important. Also take care about the material compatibility. These condensers are made out of graphite and a resin. If your chemicals affect the resin, it will swell up and you loose mechanical stability layer by layer. Often, small amines are problematic.
You can also consider silicon carbide. It shows great corrosion resistance against various chemicals. But take care about the seals between the tubes and the tube sheet. These seals (O-rings) have to be specified together with the manufacturer. You know about your chemicals and your process. The manufacturer knows about the mechanical design of his HX.
If you can afford tantalum condensers, go for it. But usually they are too expensive.
Mersen as potential supplier was already mentioned. They offer Graphite, SiC and Tantalum.
Cheers,
Michael
#8 breizh
  • 6,925 posts
Posted 10 August 2020 - 06:34 AM
another possibility .
You may consider  Tantalum coating on SS :
https://tantaline.co...eat-exchangers/
Agree with MIkeCH' comments about graphite condenser .
As a consequence  you need to have a spare equipment in maintenance workshop in case of troubles .
Edited by breizh, 10 August 2020 - 06:38 AM.
#9 stelu85
stelu85
  • 17 posts
Posted 14 August 2020 - 04:46 AM
ty for help, i'll go for different quotes and see what's best in a cost-benefit scheme.
#10 TheChemEng
TheChemEng
  • 47 posts
Posted 03 October 2020 - 02:21 PM
We use the graphite block design.
Tantalum, as breizh has mentioned, is an alternative and we also operate with these without issue but I am aware that the tantalum is pretty expensive.
