Hi All,
I'm simulating Toluene Methanol Alkylation reaction in DWSIM. For this, which reactor should I choose from the palette of reactors?
Also, can someone please share the stoichiometric reaction for the same.
Posted 13 August 2020 - 11:37 AM
Hi All,
Posted 21 August 2020 - 07:36 PM
Hi Which reactor you use depends on the amount of information you have on the reaction. You may want to start with the
Gibbs reactor. It can compute products based on 'free energy of reactant and products.
that should get you in the ball park. Next if you can get an
equilibrium constant try the 'Equilibrium Reactor. Finally as a last resort try the 'Conversion Reactor'. You tell if what conversion you want to achieve. Remember most of these reactor models work best with gas phase reactions.
Dwc SimulationStarted by Guest_Yasmine_* , 11 Nov 2026 |
Pfr Simulations In Dwsim SoftwareStarted by Guest_Knickknack_* , 01 Jul 2026 |
Simulation Of Natural Gas Water Dew PointStarted by Guest_guoyinyanliner_* , 03 Nov 2025 |
