High Pressure Spherical & Bullet Storage Rule
Posted 15 September 2020 - 10:22 PM
Posted 16 September 2020 - 05:32 AM
Can you be a little more specific about your requirement?
a general response:
You need to follow the statutory requirement of the country where the sphere/bullet will be installed.
For smaller volumes use bullet and larger volumes use sphere. There are countries where the mounded bullet is mandatory for safety reasons and there you do not have any options. The requirements will be specified in the local standards.
Posted 16 September 2020 - 05:37 AM
I think there is a criteria for Sphere and Bullet selection in GPSA
Posted 16 September 2020 - 09:12 AM
Gas storage is provided only for small volumes. So, what are you storing?
Posted 16 September 2020 - 11:40 AM
Yes...bobby is correct...I thought you need storage for liquefied gas
Edited by Chemitofreak, 16 September 2020 - 11:41 AM.
Posted 19 September 2020 - 12:24 PM
The design of either one, Sphere or Bullet, is covered by 'the ASME Boiler and Pressure Vessel Code, Section Viii Division !.
Posted 31 October 2020 - 09:14 AM
EEMUA Publication 190 Guide for the design, construction and use of mounded horizontal cylindrical steel vessels for pressurised storage of LPG at ambient temperatures
Edited by Francesco_Chem_Eng, 04 November 2020 - 01:22 AM.
Pressure BuildupStarted by Guest_Yankee_* , 31 Mar 2026 |
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
