Indirect Steam Generator With Solar Water Heat
#1 yogeshmoghekar
yogeshmoghekar
Posted 12 October 2020 - 04:43 AM
Hi, I need help on Indirect Steam Generator with Solar water (Thermal) heat.
Can we generate the steam in heat exchanger with solar water heat. I think Yes & i also know that we can use only sensible heat.
Need to know how to size the heat exchanger for this application & if any one can give the detail calculator which will be really helpful.
Eg. Solar water heat at 180 Deg C & flow rate is 45000 m3/hr. Need to generate Steam in Indirect generator (or heat Exchanger) at the max point. Can we able to consider DT @ 5, 10, 15, 20 Deg C. Which one will be best.
  • 7,031 posts
Posted 12 October 2020 - 04:51 AM
For those interested with the subject :
 https://www.internat..._digital.pd.pdf
A few docs about HX to support your work :
https://www.enggcycl...ch-temperature/
https://www.pdhonlin...m371content.pdf
http://www.engineeri...mal/sizing.html
https://checalc.com/.../ShortExch.html
note : I believe the energy content of your stream  is quite low therefore the return on investment is not granted ( many HX, many pumps , storage for pressurized water outlet of HXs, auto valve for steam flashing , etc).
Edited by breizh, 13 October 2020 - 12:54 AM.
#3 yogeshmoghekar
yogeshmoghekar
Posted 12 October 2020 - 06:58 AM
Thanks Breizh,
