Valve Passing
Started by sau1a86, Oct 17 2020 04:16 PM
Posted 17 October 2020 - 04:16 PM
We have a air blower for transfer of biomass into a cyclone then into a lock hopper followed by a surge hopper connected to a reactor via a screw. The gas in the reactor is hydrogen. However the valves between cyclone and lock hopper and lock hopper and surge hopper passes and there are chances of hydrogen back flow. Although there is a nitrogen purge to the screw to Prevent this. How can I prevent this hydrogen back flow through these passing valves?
Posted 19 October 2020 - 12:25 AM
Please upload a simple sketch of the system you described to get a proper reply...
How To Size A Presure Equalization Line For A 10" Pipeline ValveStarted by Guest_Rerrizftt_* , 14 Jul 2026 |
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Minimum Distance Between Blowdown Valve And Cold Vent Outlet In A HighStarted by Guest_AMINEBELAL_* , 15 May 2026 |
Sizing Fire Case Relief Valve Installed Below Liquid LevelStarted by Guest_processrock_* , 14 Apr 2026 |
