Hi everyone,
I want to calculate actual heating value of k-type reboiler in TEG regeneration collumn in order to compare it with design data. The reboiler is an electrical heater with 3+1 tube arrangement.
Should I set boundaries to reboiler only or include whole regeneration vessel?
What kind of steps/inputs are required?
Can I apply calculation of distillation column to above mention issue?
Appreciate your advise.
Teg K-Type Reboiler (Electric) Heating Value
Started by Limestone, Nov 05 2020 05:20 AM
No replies to this topic
Choosing The Right Type Of Evaporator For Removing Hcl From Aqueous SoStarted by Guest_anggara_* , 09 Feb 2026 |
Best Heat Exchanger Type For Gas HeatingStarted by Guest_Gole_* , 29 Jan 2024 |
District Heating Network (Demand-Driven)Started by Guest_portal266_* , 28 Jan 2026 |
