Gas Blowby Lcv Vapor Cv
#1 smeues
smeues
Posted 21 December 2020 - 03:10 PM
I'm in t he process of sizing the PSV for a vessel immediately downstream from the inlet production separator and I am currently evaluating the gas blow by scenario. The production separator's LVC is a fisher D body valve. I cannot find a vapor Cv for this valve, and I also am not sure how to calculate this because both the Cv and Q (vapor flowrate) is unknown. Q = 962 * Cv * SQRT(SG* T / P1^2 - P2^2)
Any help is much appreciated! Thanks in advance!
#2 Bobby Strain
Posted 21 December 2020 - 05:11 PM
You should contact Emerson. Some companies require sizing for the bypass valve open, too.
Edited by Bobby Strain, 21 December 2020 - 05:12 PM.
#3 breizh
  • 6,939 posts
Posted 21 December 2020 - 07:40 PM
You may find hints in the document attached .
https://www.ar-resou...-control-valves
Check the PDF after opening the link above .
Edited by breizh, 23 December 2020 - 01:44 AM.
#4 Chemitofreak
Chemitofreak
  • 292 posts
Posted 22 December 2020 - 04:43 AM
You know the manufacturer, make, model and size. Please ask the vendor, he will help you out.
#5 latexman
  • 1,893 posts
Posted 22 December 2020 - 08:41 AM   Best Answer
Try this http://letmegoogleth...D control valve
Next time, Google it yourself.
Edited by latexman, 22 December 2020 - 08:43 AM.
#6 fallah
  • 5,026 posts
Posted 22 December 2020 - 11:46 PM
At first you should ask relevant vendor to help, otherwise you can estimate the vapor flow rate by modelling the LCV as an specified orifice across which a differential pressure P1-P2 has been established once the vapor flow is passing through...
