Can you recommend a recent reference for cost engineers to cost process unit equipments based on parameters (e.g. capacity, flow rate)
Andreas
Posted 22 December 2020 - 06:54 AM
Andreas
Posted 22 December 2020 - 07:44 AM
Consider this reference : Process Industry Economics by David Brennan -ELSEVIER
Note : When possible better to get a quote from Vendors ! For Engineering companies it's easier they own data from previous projects .
Good Luck
Edited by breizh, 22 December 2020 - 07:51 AM.
Posted 05 January 2021 - 03:40 AM
Good Luck
Thanks Breizh,
The purpose of this is to use it at conceptual phase.
Process Plant Insights Dot ComStarted by Guest_Pilesar_* , 08 Sep 2026 |
Acetic Acid Plant Using The Cativa Process.Started by Guest_Pilargalizia_* , 02 Jul 2026 |
Density Meter For Inline Process Monitoring In A Distillation ColumnStarted by Guest_ProcessAtWork_* , 18 Jun 2026 |
Ai For Designing Of Process PlantStarted by Guest_Biomass Process_* , 12 Jun 2026 |
How To Estimate The Water Dewpoint From Heat And Mass Balance Of NaturStarted by Guest_krishnnaa26_* , 30 Apr 2026 |
