Finding The Density Of A Catalyst
#1 Rachel Tee
Rachel Tee
  • 11 posts
Posted 23 February 2021 - 10:17 AM
I am given that the volume of catalyst used is 4.87m3 and volume of reactor is 162.44m3. The area of catalyst is 2.9m2/g. Does it make sense that I use the surface area of reactor divide by the area of catalyst to get the mass of catalyst. Afterwards, use the mass of catalyst divide by the volume of catalyst to get the density of the catalyst??
  • 1,628 posts
Posted 23 February 2021 - 12:16 PM
Put your proposed equation into an engineering format with complete units of measure and conversion factors. I think you are trying to jump to an answer instead of working through the problem step by step. Somewhere you need to account for geometrical shape.
#3 SilverShaded
SilverShaded
  • 237 posts
Posted 24 February 2021 - 05:46 AM
The surface area is irrelevant.
You need mass and volume.  Assuming you are looking for bulk density you need to know how much weight of catalyst was added to the volume of the reactor.
#4 breizh
  • 6,917 posts
Posted 24 February 2021 - 06:02 AM
Bulk density and catalyst density are related to each other  but you need the porosity of your bed .
Ro bulk = Ro Cat  *(1-phi)
phi =porosity
SSA = A/(V*Ro)
SSA : m2/kg Specific surface area  .
A:m2  area
V m3  volume
Ro :kg/m3 density
My 2 cents
Edited by breizh, 24 February 2021 - 08:55 AM.
#5 Nikolay_
Nikolay_
  • 167 posts
Posted 31 May 2022 - 01:40 AM
Hi breizh,
Do you have any reference data on catalysts density for the formula?
#6 breizh
  • 6,917 posts
Posted 31 May 2022 - 03:51 AM
Hi Nikolai ,
Sorry I don't have data to support but you can find video on Youtube explaining the relation between Bulk density and solid density of catalyst with application to PBR .
Hope this is going to help you.
#7 Nikolay_
Nikolay_
  • 167 posts
Posted 31 May 2022 - 06:40 PM
Thank you.
