Molecular Sieve In Flare
#1 Guest_Amandeep Bhanu_*
  • guestGuests
Posted 27 October 2006 - 04:39 PM
What is molecular sieve? How it works or What is the construction of molecular sieve associated with flare stack? What is the purpose of giving water seal in molecular sieve?
Posted 27 October 2006 - 05:08 PM
Amandeep:
If you are not a Chemical Engineering Graduate, you probably don't know about Adsorption, one of the Unit Operations. And if you don't know about adsorption, then that may explain why you don't know that molecular sieves have nothing to do with flare systems.
You are obviously mixed up with respect to your Unit Operations. I recommend you get on a Search Engine like Google and search for Adsorption followed by Molecular Sieves. You will get millions of "hits". Find out what it is and then you ask your specific questions.
#3 joerd
joerd
  • 371 posts
Posted 27 October 2006 - 10:28 PM
@Amandeep:
You may be confusing Molecular Seal and Molecular Sieve. Take Art's advice and use Google to your advantage!
