Edited by lnbsak, 05 June 2021 - 07:29 PM.
Loop Convergence With Different Water Content In Two Different Loop
Posted 05 June 2021 - 07:25 PM
Posted 06 June 2021 - 06:45 AM
There is not enough information supplied to give you a definite answer. If 'some amount' of water is insignificant to the process and only causes numerical issues, then you can remove the water component from a stream and not recycle it. If 'some amount' is important to the recycle and you can estimate the amount of water, then add a fixed amount of water back as a separate stream. These are just techniques you might use. All simulations are wrong in some way and the goal is to make them useful for your purposes. When you achieve the goal, there is no reason to fiddle further with the simulation.
Posted 09 June 2021 - 03:30 AM
Thank you so much sir for your answer. Actually I was little worried as there is one compressor in the recycle stream. So my thought was do we have to use special moisture controlling equipment. If yes how much water should be in the stream in the first place?
Edited by lnbsak, 09 June 2021 - 03:32 AM.
Aspen Plus Convergence ErrorStarted by Guest_NavidJon9_* , 29 Apr 2024 |
Chiller Efficiency Dependence On Cooling Water TemperatureStarted by Guest_Neha Vensiyani_* , 29 Apr 2024 |
Waste WaterStarted by Guest_refluxraider_* , 14 Apr 2024 |
Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Rapid Depressurization Of WaterStarted by Guest_golegolegole_* , 31 Mar 2024 |
