Fire Protection Of Tanks
Started by chanchalg, Jun 11 2021 06:14 AM
Posted 11 June 2021 - 06:14 AM
Hello Everyone!
What is difference between fixed and semi fixed foam system for storage tanks?
Thank you!
Thank you!
Posted 11 June 2021 - 06:32 AM
Fixed - everything is "hard piped" and permanent.
Semi-fixed - usually the foam generating agent is moved from storage (where conditions are ideal for long storage life) to the field location where it is connected to the "fixed" part of the system so it can be activated and foam generated.
Try your favorite search to get answer !
https://www.chemguar...s/D10D03192.pdf
Condensate Storage Tanks In-Breathing And Out-BreathingStarted by Guest_MethanolPlant_* , 26 Apr 2024 |
Psv Fire Case Relief Load CalculationStarted by Guest_mahmooddalvi09_* , 21 Feb 2024 |
Determination Of The Number Of Foam Chambers For Storage TanksStarted by Guest_AnbIran_* , 15 Feb 2024 |
Fire Ball DistinguisherStarted by Guest_Rahimzadeh_* , 22 Dec 2023 |
Overpressure Protection For TanksStarted by Guest_Chemcato_* , 21 Dec 2023 |
