1
Ethanol Dehydrogenation Aspen Hysys Ver 11 Simulation
student hysys ethanol aspen simulation dehydrogenation acetaldehyde
#1 marie_02
marie_02
Posted 16 June 2021 - 11:22 AM
Hi! I've been trying to simulate four distillation columns for ethanol dehydrogenation using ASPEN Hysys version 11. I've already simulated the distillation columns but whenever I try to recycle it in the feed it won't converge. Can someone help me or give me some hint or guidelines for it to converge. Thank you!
#2 Bobby Strain
  • 3,018 posts
Posted 16 June 2021 - 02:40 PM
You need to post your flowsheet. The first thing to try is to simulate using a dummy recycle stream without a recycle block. You probably mean dehydration, i.e. water removal.
Edited by Bobby Strain, 16 June 2021 - 10:33 PM.
#3 marie_02
marie_02
Posted 17 June 2021 - 12:50 AM
Thank you sir for the reply. I already tried using a recycle stream and I still can't get the required compositions. Here is the link of what I'm trying to simulate  https://docplayer.ne...rogenation.html
Edited by marie_02, 17 June 2021 - 12:53 AM.
#4 Bobby Strain
  • 3,018 posts
Posted 17 June 2021 - 03:00 PM
Adjust the tolerances of the recycle block. Loosen the requirements until you get a converged solution. Then tighten them.
