Hydrate Formation (Upstream Or Downstream Pressure)
pressure control downstream pressure hydrates
#1 rs20170808@gmail.com
  • 41 posts
Posted 04 July 2021 - 02:55 AM
i have a gas expanding thru a control valve ...
upstream pressure is 400 psig and downstream is 50 psig
upstream temp is 80 F and downstream is 50 F
At upstream pressure hysys show hydrate formatiion at 56 F
at downstram pressure hysys show hydrate formation at 35 F
What should be considered ...will hydrate form? since downstream temp. 50 F > 35 F so no formation?
which pressure should be considere for analysis?
  • 1,637 posts
Posted 04 July 2021 - 03:33 AM
Hydrate formation tendency is affected by pressure, temperature, and composition. Consider the stream composition at its conditions: upstream pressure at the upstream temperature and the downstream pressure at the downstream temperature.
#3 PaoloPemi
PaoloPemi
  • 550 posts
Posted 04 July 2021 - 01:45 PM
given composition, hydrate formation temperature depends from pressure as said by Pilesar,
see the image below created with the free online calculator
https://www.prode.co...ies/hydrate.php
Edited by PaoloPemi, 05 July 2021 - 01:08 AM.
