Hi, I'm carrying out a review of our vent header arrangement and I was wondering if anyone could provide their thoughts/guidance on the following query:
Vent header
The vent header itself serves a chemical facility and consists of 4 individual headers that combine and exit via tall stack. Each header has a collection of vessels breathing into it, blanketed/unblanketed storage tanks and process vessels etc. These vessels emit a range of flammable VOCs (toluene and similar compounds)
Basis of safety
The basis of safety for the header is 'absence' of flammable atmosphere allied with absence of ignition source.
This is achieved by inerting the each header with nitrogen at a given flow-rate and avoiding any source of ignition (vents are just pipes, so static from abnormal liquid or propagation of ignition from a vessel).
Query
My query is regarding what should this given flow-rate be and is there any guidance available as I've not been able to find any?
My thoughts
Keeping the oxygen level below 5% for the 'majority' of the time is my starting point.
Look at all the operations and the corresponding out-breathing rates across the multiple units and assume they are undergoing initially purging (air venting) - if I have eight vessels, do I assume eight simultaneously or do I pick a more realistic number say 1-2 that would cover the majority of realistic cases?
We also carry out vacuum operations that will inherently flood the vent periodically for a short duration with high levels of oxygen and to accommodate this with higher nitrogen flows seems very uneconomical and impractical.
In essence, I'm hoping to hear what approaches/methodologies others have used in their experience along with their justification and if they referenced any particular available guidance?
Andrew
Edited by AndyChemEng, 21 August 2021 - 08:15 AM.
