Steam Reforming - Real Reformer Simulation Hysys
hysys reforming reformer simulation catalyst
56 replies to this topic
#51 PingPong
PingPong
  • 1,477 posts
Posted 22 December 2021 - 03:46 AM
No, when making a design you can get any bridgewall temperature you like, irrespective of the air preheat temperature, because you simply choose it.
Based on air preheat temperature, fuel composition and % excess air you can use Aspen to calculate the adiabatic flame temperature T1. Aspen will also give you flue gas properties.
Then you choose the bridgewall temperature, say T2.
When your radiant duty, including some heat loss, is Qr then you can simply calculate how much flue gas has to be cooled from T1 to T2 to provide Q
You can do this for several air preheat temperatures, say 350, 400, 450 and 500 oC as you don't know yet what your air preheat in the convection section will be.
Edited by PingPong, 22 December 2021 - 03:46 AM.
#52 daraj
daraj
  • 222 posts
Posted 22 December 2021 - 11:55 PM
Thanks. for sizing the reformer tubes, what is the typical flux used for a top-fired reformer for hydrogen production? and the dimensions of the tubes?
#53 PingPong
PingPong
  • 1,477 posts
Posted 23 December 2021 - 03:35 AM
You should really read all my posts in the other topic that I mentioned to you before:
https://www.cheresou...-reformer-unit/
#54 daraj
daraj
  • 222 posts
Posted 24 December 2021 - 03:06 AM
OK,I will, thanks a lot for your inputs
#55 daraj
daraj
  • 222 posts
Posted 14 January 2022 - 01:22 AM
Pingpong, the term "absorbed duty" in the contect of a fired heater/reformer, does it refer to the duty that is actually usefully utilized. i.e if 100 MW of fuel is burnt and 90% is overall efficiency, then 90MW is the absorbed duty here?
also do you know of any cost vs duty correlations for steam reforers? lets say i have a top fired reformer of 500 MMBtu/hr of absorbed duty(or useful duty i understandn it), then wondering what would be typical USGC installed cost?
#56 PingPong
PingPong
  • 1,477 posts
Posted 16 January 2022 - 04:52 AM
The term "absorbed duty" can be used for individual coils in a reformer heater.
If you would use it for the whole heater then you need to indicate that it is excluding the air preheat coil duty as that absorbed duty does not leave the heater but is merely recycled back to the burners.
Including APH the absorbed duty of all coils together can be higher than the fired duty but that obviously is not relevant.
also do you know of any cost vs duty correlations for steam reformers? lets say i have a top fired reformer of 500 MMBtu/hr of absorbed duty(or useful duty i understand it), then wondering what would be typical USGC installed cost?
I don't have accurate and up to date cost data for SMR units.
Graphical representation of installed cost for SMR unit is usually as function of hydrogen product.
See for example this graph from the book: Petroleum Refining Technology and Economics 5th Edition - Gary, Handwerk & Kaiser 2007  which gives investment cost in 2005. You need to increase that number (using CEPCI) to obtain today's investment cost.
Attached File  Investment cost SMR Unit 2005 USGC.jpg   99.99KB   4 downloads
Edited by PingPong, 16 January 2022 - 05:17 AM.
#57 daraj
daraj
  • 222 posts
Posted 18 January 2022 - 06:48 AM
OK, thanks
