Hello everyone,
I would like to ask you if it correct to say that a steam furnace can be considered as heat recovery steam generator?
Also, could you provide me any material related to heat recovery steam generators?
Thank you in advance!
Posted 13 October 2021 - 03:06 AM
Hello everyone,
Posted 13 October 2021 - 03:41 AM
Just Google : heat recovery steam generator
A lot of documents are available .
Posted 13 October 2021 - 04:34 AM
The phrases 'steam furnace' and 'heat recovery steam generator' are not commonly interchangeable terms referring to the same equipment. By 'steam furnace' are you referring to a blast furnace for smelting where the blowers are powered by steam? Or do you mean something else?
Posted 13 October 2021 - 06:57 AM
Hi Pilesar thank you for your reply. I am referring to the steam cracker in the ethylene plant, which I consider it as a heat recovery steam generator. What do you think?
Posted 13 October 2021 - 09:29 AM
You can call it what you like. If you want to be understood, use terms generally used.
Posted 13 October 2021 - 11:36 AM
Hi Bobby,
What are the terms that I used which are cannot be understood?
Posted 13 October 2021 - 12:44 PM
There are steam generators at several locations in a steam cracker. And they do have common terms to identify each of them.
Posted 13 October 2021 - 02:36 PM
Hello Bobby,
as far as I know the only location of steam generation is the transfer line heat exchanger, which rapidly cools down the produced cracked gas. I do not really know the other locations.
Posted 13 October 2021 - 02:55 PM
Well, you got the name right.
Posted 14 October 2021 - 04:00 AM
Thanks Bobby for your answer. May I ask you in which other locations in the ethylene plant we can have waste heat recovery system?
I assume that the auxiliary boiler (which is normally for start-up or to "support" the extra steam required for downstream) is not consider as heat recovery system?
I anticipate your answer.
Posted 14 October 2021 - 05:01 AM
Installation Of Vertical Pass Partition Plate In Kettle Type Steam RebStarted by Guest_jigs1980_* , 09 Sep 2026 |
Screening Heat & Material Balances Cases For Fire Relief Psv SizinStarted by Guest_powerox6_* , 21 Aug 2026 |
How To Right Size A Vapor Recovery Unit (Vru)?Started by Guest_MethanolPlant_* , 29 Apr 2024 |
How To Estimate The Water Dewpoint From Heat And Mass Balance Of NaturStarted by Guest_krishnnaa26_* , 30 Apr 2026 |
