Is there a quick way to size the vent size for a tank that gets filled with solids?
Posted 09 November 2021 - 09:06 AM
Posted 09 November 2021 - 09:40 PM
Not clear to me what you are looking for ! I've seen goose neck with sock attached , is it what you expect ?
How the tank is fed ? conveyor or pneumatic transport ?
You should consult suppliers of dedusting system .
What is important to know is the material you store in silo, the particles size of the dust and its ability to react with moisture which will impact the shelf life of socks on dedusting system .
On a safety view point consider the risk of dust explosion.
Good to read the document in the links.
http://www.concretea...ntion Guide.pdf
https://cement.miner...on_Guidance.pdf
Posted 10 November 2021 - 06:20 AM
1-Estimate the maximum rate of solid filling in m3/hr...
2-Estimate the vent size based on estimated rate in the first step and mach number equal to 1
3-Get the minimum size of the vent equal to one size larger than the size estimated in the second step
Posted 10 November 2021 - 06:44 AM
4- Check the tank backpressure is less than (or equal to) tank design pressure.
Posted 10 November 2021 - 08:14 AM
Thanks for your completion...
Posted 13 January 2022 - 12:09 PM
What exhaust velocity shall I use?
And how can you calculate the back pressure at the exhaust?
Posted 13 January 2022 - 12:23 PM
The exhaust velocity that results at the maximum rate of solid filling in m3/hr (#1).
You really haven't told us any details. What does the installation look like? So my reply can be more specific than - you know just outside the exhaust you have atmospheric pressure. Then work backwards.
In Hysys, For Horizontal Vessel Sizing,Started by Guest_guoyinyanliner_* , 10 Sep 2026 |
Sizing Two-Phase And Three-Phase SeparatorsStarted by Guest_guoyinyanliner_* , 03 Sep 2026 |
Minimum Distance Between Blowdown Valve And Cold Vent Outlet In A HighStarted by Guest_AMINEBELAL_* , 15 May 2026 |
Sizing Fire Case Relief Valve Installed Below Liquid LevelStarted by Guest_processrock_* , 14 Apr 2026 |
Gas Blanketing Vent Size For Atmospheric Storage TankStarted by Guest_Fergie_* , 13 Apr 2026 |
