How Many Stages Of Falling Filme Evaporator
#1 Orzelgorskiego
Orzelgorskiego
  • 28 posts
Posted 03 January 2022 - 07:44 AM
Could somebody explain more precisely how to determine the number of stages for multiple installation of evaporators. Maybe we can use an example.
I have stcickwater flow of 4800kg/hr and I would like to evaporate 3200kg/hr .
I have residueal vapour of 1800kg/hr which will go to the evaporator.
How many stages should I use? I, II or III?
Thank you
Enable Ginger
Cannot connect to Ginger Check your internet connection
or reload the browserDisable in this text fieldRephraseRephrase current sentenceEdit in GingerĂ—
Enable GingerCannot connect to Ginger Check your internet connection
  • 6,720 posts
Posted 03 January 2022 - 08:00 AM
Consider the table 8-1 in my initial post .
It's all about the pay back of the project ( Operating cost vs Investment ) , comparison between single effect and multiple effects .
You need also to consider the cost of the energy and availability ( quantity and Pressure) , in house or outsourced .
Another option could be a single effect coupled with VMR .
note : Pay attention to the metallurgy of the equipment , perform corrosion study with the liquid you want to concentrate.
Documents are attached to support your work .
Good luck .
