How To Convert Kvs-Value For Water To Kvs For Gas?
kvs
8 replies to this topic
#1 Falko
Falko
  • 3 posts
Posted 12 January 2022 - 01:43 AM
for an instrument I have given the Kvs-Value for water and I want to convert it to gas. Can someone help or explain the calculation?
Of course i  have the formulas for liquid and for gas calculation.
How do i convert it?
Thanks for the help
Falko
  • 6,975 posts
Posted 12 January 2022 - 04:58 AM
I'm not sure i understand the query . Do you mean you have a control valve for water and you want to use it for gas ?
https://www.engineer...nts-d_1931.html
#3 latexman
  • 1,902 posts
Posted 12 January 2022 - 08:32 AM
You can transform Kvs into a dimensionless K value (or is it a C value in Europe?), then it can be used for all gasses and liquids alike.  Just use the correct equations for the situation - incompressible, compressible, choked, etc.  To transform Kvs just substiture the definition of Kvs into the Darch equation.  If this does not sound familiar, I recommend you seek and obtain Crane Technical Paper 410 as a reference.
#4 Falko
Falko
  • 3 posts
Posted 12 January 2022 - 09:22 AM
Yes, it's a check valve and i have the Kvs for water and i need it for air, but i don't know how to convert it. The formulas for liquid and gas I know/have. Can i put the liquid Kvs on the left side of the gas equation and then e. g. calculate the volume flow? Kv=Vg/519 * root((rohGT1)/(delta p * p2)  I have a liquid Kvs and need a relation to a gas flow. Liquid Kvs is 42 m³/h for water, How much air can I put threw the valve?
Thx for your help.
Falko
#5 latexman
  • 1,902 posts
Posted 12 January 2022 - 10:33 AM
What is the numerical value of Kvs for water of the check valve?  What pipe diameter is the check valve?
Using symbology it is Kvs m3/hr at a pressure drop of 1 bar.
The Darcy equation for a valve is hL = K v2/2g.  Remember, K ≠ Kvs.
So calculate the velocity given Kvs m3/hr and the pipe ID.  Calculate the head loss that corresponds to 1 bar.  Calculate K.
Now use that K with the gas properties and the pertinent gas equation to get what you need.
#6 Falko
Falko
  • 3 posts
Posted 13 January 2022 - 07:07 AM
I have the check valve DN50 with a Kvs of 42 m³/h for water. I want to use it for air. How much air can go through it? On one side is the atmosphere, on the other side is maximum -100 mbar.
How much air can go through it? Hoch much air will go through under this conditions? How much air at opening 100%?
Thanks for your help
Falko
#7 breizh
  • 6,975 posts
Posted 13 January 2022 - 07:53 AM
Hi Falko ,
It's difficult to understand your query .  A check valve is not an instrument , it's an equipment .Like any other fittings, it follows the Darcy Weisbach equation (head loss versus [ velocity or Flow rate } ^2 .
BTW which type of check valve are you talking about? what is the brand?
https://www.rusa-or....eck Valves1.pdf
In operation the check valve must be fully open  this means you have to find the relevant catalogue for this piece of equipment ( Internet is another option) and check its capacity for air .
My view
#8 latexman
  • 1,902 posts
Posted 13 January 2022 - 08:13 AM
Is the check valve spring loaded?  If so, what is it's cracking pressure (CP)?  If CP > 100 mbar, then flow is zero.  Is the check valve screwed, flanged or welded connections?
I can help get you part of the way to the answer with what we know already:
42 m3/h = 700 LPM.
In DN50 (2" Sch. 40 = 2.067" ID), v = 17.7 ft/sec (5.4 m/sec)
For a pressure drop of 1 bar (14.5 psi), K = 6.9 (dimensionless).  See attached .pdf.
If the check valve is not spring loaded, it has a relatively large resistance compared to 2" swing check.  What type check valve is it?  A lift check?
You see, we are guessing, because you have failed to give complete, detailed information.
#9 breizh
  • 6,975 posts
Posted 20 January 2022 - 09:56 PM
Consider this resource :
https://neutrium.net...en-cv-kv-and-k/
