Fancywhale:
For my own education, could you please cite the type of (TEMA?) heat exchanger being used and its size with a copy of the calculations you are verifying? Is this an existing unit, or a new, proposed one? I assume this is a real-life industrial application.
A nominal size of 1,000,000 lb/hr of supercritical CO2 placed on what is normally the weakest structural side of a heat exchanger is enough to raise the eyebrows of a lot of people – especially if the shell is designed for approximately 2,450 psig as MAWP. That’s why I’m curious of the type and construction of the heat exchanger in question. This raises a lot of questions regarding the scope of work and basic data… stuff that can’t be handled in a forum posting. Bobby, Pilesar, and Breizh are right on top of the importance and logical way to handle this type of process problem: get local, expert and experienced help and advice on this assignment. I’m not afraid of supercritical CO2 – and I’m sure neither are Bobby, Pilesar, or Breizh. I’ve worked with this fluid for many years in my young engineering years. But we are all – I am sure – aware of the many strange things that are exhibited by this “4th”, not fully understood, phase that oft times defies the predictions of current Equations of State. The stuff seems to be very compressible. I even handled it in reciprocating compressors. It exhibits extraordinary properties in dissolving and absorbing a lot of stuff. It has been used to selectively decaffeinate coffee beans for over 60 years. It continues to be studied. See the attached.
My main point here is that the advice heeded by Bobby, Pilesar, and Brieizh should be followed if you are indeed encharged with designing a relief system for a heat exchanger handling supercritical CO2 – not because you are unqualified, but mainly because you lack sufficient years of experience in the field of handling this type of problem. You deserve all that help and the project needs it. It’s the smart, engineering thing to do.
Transportation of CO2 in Dense Phase January 2012.docx 226.11KB
12 downloads
