Operating Pressure In Distillation Column
#1 rosesdaf
rosesdaf
  • 6 posts
Posted 05 April 2022 - 07:22 AM
I am designing a distillation column that involves ethylbenzene, benzene, toluene and styrene, with the aim of recycling ethylbenzene. The column operates at 1.2 bar according to the simulation in literature, however, I am figuring out why 1.2 bar is used as it is very close to atmospheric pressure and it results in higher operating costs unless there is a legitimate purpose relating to safety due to the carcinogenic nature of benzene. I was wondering if it is appropriate change the operating pressure to 1.01325 bar instead for my case.
Thank you very much.
  • 1,632 posts
Posted 05 April 2022 - 10:35 AM   Best Answer
This column will likely have a relief valve and a vent discharging to a flare header. The pressure needs to be higher than the flare header pressure so there is no problem with vapor backflow into the column. There is the possibility of an equipment leak to the atmosphere and any air leaked into the column might contribute to an explosive mixture. This means that atmospheric pressure columns usually operate a little bit above atmospheric pressure. Fluid flow requires pressure drop and a controlled slight positive pressure in equipment makes the engineering easier. Distillation pressures are typically set to accommodate the economical condenser and reboiler utilities. Low pressures result in easier for component separation. Higher pressures have lower vapor volumes allowing smaller column diameter but may require more stages and perhaps a thicker vessel wall. The economic optimum may not be intuitive.
#3 rosesdaf
rosesdaf
  • 6 posts
Posted 06 April 2022 - 03:32 AM
Thank you Pilesar! It's clear now.
#4 Pilesar
  • 1,632 posts
Posted 06 April 2022 - 05:08 AM
Component distillation under vacuum pressure is sometimes necessary for fluids very sensitive to heat since the boiling temperatures would be lower. High temperatures can promote decomposition and other unwanted reactions. Since the components in your system are not troublesome, vacuum distillation is not required. Distillation at elevated pressures might be selected when it makes sense for the system flowsheet.
   Process integration leads to compromises. Where one process flowsheet compresses a vapor product, another flowsheet for the same product may instead compress the feed. Design choices for one piece of equipment can have ripple effects on others. Over-optimizing a distillation column (e.g. let's reduce the pressure just a few percent) may lead later to a complete redesign of the tower and condenser and reboiler when you find you need just a little more pressure than you assumed. Designers add a safety factor to equipment designs instead of shaving every last bit of extra margin. This allows room for the field operators and engineers to make additional optimizations to make the plant run 'better than designed.' For your column, the field may determine to target 1.15 bar operation instead of the designed 1.2 bar. As long as they can do so safely, there may be more profit for them with manageable risk. That would not mean the designer was wrong.
