Can anyone please tell me at what temperature theCarbon and Hydrogen Bonds in Propane disassociates.
Thanks to everyone who can help me.
Temperate At Which The Carbon And Hydrogn In Propane Breaks
Started by harinath reddy, Nov 08 2006 04:47 PM
Posted 08 November 2006 - 04:47 PM
Posted 09 November 2006 - 04:55 AM
You suggest that there is one particular temperature above which the C-H bond will break. It doesn't work like that. The dissociation reaction is:
C3H8 <---> C3H7· + H·
Reaction speed can be modelled with the Arrhenius equation. Following is copied from http://www.shodor.or.../arrhenius.html
"Common sense and chemical intuition suggest that the higher the temperature, the faster a given chemical reaction will proceed. Quantitatively this relationship between the rate a reaction proceeds and its temperature is determined by the Arrhenius Equation. At higher temperatures, the probability that two molecules will collide is higher. This higher collision rate results in a higher kinetic energy, which has an effect on the activation energy of the reaction. The activation energy is the amount of energy required to ensure that a reaction happens.
k=A*exp(-Ea/R*T)
where k is the rate coefficient, A is a constant, Ea is the activation energy, R is the universal gas constant, and T is the temperature (in degrees Kelvin).
R has the value of 8.314 x 10-3 kJ mol-1K-1"
Following link seems also interesting: http://pubs.acs.org/.../jp030597f.html
k=A*exp(-Ea/R*T)
Posted 09 November 2006 - 08:41 PM
Thanks for your reply. Actually the way i asked the question is bit wrong.
For example consider Methane, Break down of methane hydrate commences at 272.8 K,approximately after 10 hours. At 273 K it achives 100% reaction in a reasonable time. Dissociation is complete after 3hours at 273.6 to 273.8 K and only 18 minutes at 288.8 K.
This is what i want to know for propane.
thanking you
Harinath Reddy Bussu
thanking you
Posted 10 November 2006 - 03:07 AM
I would say that the melting of methane hydrate is more similar to melting of ice and that it can not be compared with the dissociation reaction of propane. My advise for you is to study reaction kinetics in more detail. You can start this by reading through the series that can be found on this website, starting with http://www.cheresour...kinetics1.shtml as well as the references in this series.
Propane Product Temperature Correction FactorStarted by Guest_loggrrr_* , 20 Nov 2023 |
Activated Carbon Fire RiskStarted by Guest_AndyChemEng_* , 03 Aug 2023 |
Answered
Carbon Bed Filter CalculationsStarted by Guest_kyayura_* , 25 Jul 2023 |
Carbon Filter Used In Hot Benfield Solution For Co2 Removal In AmmoniaStarted by Guest_Abhishek Taware_* , 14 Jul 2023 |
Hydrocarbon Dew Point Control Using Propane Refrigeration Loop.Started by Guest_BabRafiq1_* , 10 Jul 2023 |
