Vent Area Calculation
#1 Kiran T
Kiran T
  • 24 posts
Posted 16 July 2022 - 06:57 AM
hi,
I wanted to clear my doubt on vent area calculation equation. I refer ludwig process engineering book for vent size calculation. There are two different equation for mass flow rate ( lb/hr)  and volumetric flow ( SCFM) for calculation of vent size. can any one tell why there are two equation ?
Can i convert Volumetric flow rate in mass flow rate and use the equation vice versa ?
#2 latexman
  • 1,893 posts
Posted 16 July 2022 - 07:52 AM
You should be able to convert one equation into the other. Try it.
#3 breizh
  • 6,936 posts
Posted 16 July 2022 - 08:43 AM   Best Answer
Yes you should , just pay attention of the definition of standard condition.
Edit :
To validate your work consider the document attached .
#4 horatorres
horatorres
  • 88 posts
Posted 18 July 2022 - 08:30 PM
Yes,,, check carefully the unit
horacio
#5 Chemitofreak
Chemitofreak
  • 292 posts
Posted 19 July 2022 - 01:13 AM
Both the equations should give you the same result. As it is a vent the preferred unit for flowrate is SCFM or Nm3/hr that too of air.
Be very careful about the units.
