HI all,
I need to model fractionation and crystallization.
My questions are:
For the oil characterization, I have ASTM D86 setup, ASTM D5236, and a vacuum column with reflux and 8 theoretical plates. The ASTM D86 curve is not complete and ends at around 360 deg C. For the other two, I couldn't find options to put curves in Aspen plus for modeling.
In the experiment, I get some clogging due to the formation of benzoic acid around 120 deg C vapor temperature, which I removed by operating the condenser at a high temperature. To remove benzoic acid from the oil cuts, I need to model the crystallizer. How can I incorporate benzoic acid in the boiling curve to model the crystallizer after the fractionation column?
