Lhsv-Correct Interpretation(Inputs Needed)
#1 daraj
daraj
  • 222 posts
Posted 14 October 2022 - 04:41 AM
Hi, for a quick sizing of mixed-phase reactors(such as say a trickle bed which has both liquid feed and a gas like hydrogen enteriong the reactor) I ma using LHSV values typically applied to this type of reaction from literature.
what I wanted to know was does the definition of LSHV include porosity? this is not clearly mentioned anywhere. Some say it doesn, some say it doesnt.
for example, in a lot of peer reviewed papers and articles, LHSV for  a particular reaction is mentioned as 5 hr-1.
So lets say i have a LIQUID feed flow rate of 5 m3/hr entering the reatcor. (Gas flow may be higher say 25 m3/hr)
so the bed volume = liquid flow rate/LHSV =  5/5 = 1 m3.
 now is this the bulk bed volume or just the volume occupied by the solid catalyst particles? if its the latter, i need to divide this volume further by voidage to get my bed volume.. what is the commonly accepted convention scentifically and industrially? i need this to quickly scale up a reactor based on data from literature for industrial operation.
any pointers to reactor design of this type based on LHSV is welcome. I also need to know how to figure in the gas velocity in sizing the bed and the reactor volumes. (reactor volume is > bed volume)
  • 6,938 posts
Posted 14 October 2022 - 05:08 AM
It seems there is a consensus on the definition:
http://www.eptq.com/...24-d45bfaef8c64
my 2 cents, after asking my best friend Google
#3 Bobby Strain
Posted 14 October 2022 - 09:29 AM
Ask your catalyst supplier.
#4 daraj
daraj
  • 222 posts
Posted 15 October 2022 - 02:07 AM
Breizh, thanks, although the lin you have given as inputs on everything except reactor volume definition. From what i gathered looks like the bulk bed volume(including voidage) is considered for LHSV, not just the catalyst volume, typically.
#5 breizh
  • 6,938 posts
Posted 15 October 2022 - 04:28 AM
Yes, I believe so, should include the void of the catalyst bed,
EDIT: not sure!
http://pu.edu.pk/ima...20-Feb-2014.pdf
As pointed out why don't you call or drop an email to catalyst vendor to get a final answer? In any case you will have to make the call.
BTW did you check the technical data sheet of the catalyst?
