How To Decide Between Dryer Or Methanol Coloumn
methanol dryer evaporation
#1 MiraiNikki52
MiraiNikki52
Posted 21 December 2022 - 10:59 PM
Good day to you !
currently I want to design a plant of Biodiesel. and I have a question, when you have a Methanol stream with the concentration of 60%. which equipment that I should choose in order to get 95% concentration.
mostly in the plant there would be Methanol rectification. but since the streamline only contain water, is it enough just to have dryer ?
Thank You
  • 6,998 posts
Posted 22 December 2022 - 12:34 AM
Did you check the boiling point of the materials? This should be a good start.
#3 MiraiNikki52
MiraiNikki52
Posted 07 February 2023 - 01:12 AM
the boiling point between methanol and water quite high, but in case I want to get wet methanol like 95%, is dryer already enough rather than invest bigger capex for the rectification
#4 breizh
  • 6,998 posts
Posted 07 February 2023 - 02:40 AM
I don't understand your question! what type of dryer are you talking about?
