3
Instrument Air Dryer
#1 SHIRAM
SHIRAM
  • 3 posts
Posted 29 June 2026 - 10:59 AM
Dear Team members,
Instrument air dryer uses adsorbent  Alumina for removal of moisture designed for 100 % humidity & 45 Deg C  With lower humidity and feed temperature at 35 Deg C whats is impact on performance respect to dew point and capacity of the dryer.
With regards
  • 7,062 posts
Posted 29 June 2026 - 09:39 PM
Consider this document to perform calculation about air, it should help .Another option could be Mollier Chart.
Did you try AI? You will be amazed.
  • Dew point: Likely same or better (lower) at 35 °C and lower RH than at 45 °C/100% RH, assuming regeneration is unchanged.
  • Capacity:
    • Water removal rate (kg/h) decreases because the inlet air carries less moisture.
    • Effective capacity in terms of time at spec dew point increases—the dryer will stay “in spec” longer per cycle.
#3 FRBChemE
FRBChemE
  • 35 posts
Posted 08 July 2026 - 04:34 PM
Several Simulators now have Air Dryer Technology.  If I remember correctly, DWSIM does.
