Dears,
As you know, there are two empirical equations in API 521 to quantify the heat input into fluids within vessels: one in the presence of adequate firefighting and drainage and the other is in the absence of that.
My curiosity is about the following:
1. What does define the adequate firefighting and drainage?
I'm aware that the standard somhow leaves this to the owner. So, it is somewhat vague and each one can have his/her definition.
2. Is there any standard, article, and/or reference which elaborate on this topic? If yes, I would appreciate if you can share them.
Personally speaking, I've seen engineering organizations which have two different approaches i.e. some have the default as the adequate firefighting & drainage are present while others have it the opposite.
Your feedback is highly appreciated...
Api 521 Pool Fire Heat Input Equations
Started by Vegeta, Jan 24 2023 01:57 PM
Electric Heat Tracing—Pipe-Wall Temperature Vs. Actual Fluid TemperatuStarted by Guest_zamakaze_* , 20 Sep 2026 |
How To Estimate The Water Dewpoint From Heat And Mass Balance Of NaturStarted by Guest_krishnnaa26_* , 30 Apr 2026 |
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
