Breathing Calculation For Asme Pressure Vessel
#1 Ali Akhoundi
Ali Akhoundi
  • 4 posts
Posted 28 January 2023 - 02:18 AM
Hi everyone,
Is API 2000 equations applicable to calculate the breathing flow rate for an ASME pressure vessel? If not, is there any other reference to calculate it?
Cheers
Ali
Edited by Ali Akhoundi, 28 January 2023 - 03:04 AM.
  • 7,062 posts
Posted 28 January 2023 - 06:52 AM
Review the conditions to use API 2000 in the document attached.
What are your operating conditions?
#3 Ali Akhoundi
Ali Akhoundi
  • 4 posts
Posted 29 January 2023 - 08:29 PM
Much appreciated for the reply and the attached overview of API 2000. I know API 2000 is applicable for atmospheric pressure (15 psig), but for my case (ASME pressure vessel with padding pressure around 1 barg and de-padding pressure 2.5 barg and DP 3.5 barg), am I allowed to use API 2000 equations? To me , the concept is the same , and I couldn't find any other references which addressed pressure vessels.
#4 breizh
  • 7,062 posts
Posted 29 January 2023 - 09:45 PM
HI,
You should check with your local safety bureau and/or reputable vendors of safety devices (Protectoseal, Groth, and others).
https://www.cheresou...f-asme-vessels/
