Column With Packings
Posted 25 February 2023 - 07:07 PM
Thank you in advance!
Posted 25 February 2023 - 09:00 PM
Column efficiency varies for packed columns as well as for trayed columns. The composition and flow rates for the vapor and liquid matter as well as the type of packing. Stages are usually shorter than 2 feet of height. There are lots of variables so you may want to consult the column designer or the packing manufacturer if you do not have access to the design calcs. If you have an existing column, you can use simulation to back-calculate the column efficiency using historical data.
Posted 26 February 2023 - 05:07 AM
Posted 26 February 2023 - 08:12 AM
Here is a link to an article which seems a good summary of some of the parameters affecting tower efficiency: https://chempedia.in...ked_hetp_value/
Posted 26 February 2023 - 09:29 AM
You may want to study this material .
Posted 26 February 2023 - 10:04 AM
Posted 26 February 2023 - 12:25 PM
Hi Pilesar, I thought that with the equilibrium model if you use trays or packing, the effect is on hydraulics of column and not really on the compositions. The compositions are result of number of trays and reflux ratio.
Your talking about theoretical stages of seperation not real world trays with efficiencies, 2 trays with 50% efficency are equivalent to 1 theoretical stage.
Real trays can vary between 0% and 120+% efficiency.
Edited by SilverShaded, 26 February 2023 - 12:26 PM.
Posted 26 February 2023 - 01:02 PM
Posted 26 February 2023 - 02:53 PM
Hi Silver, I am refering to theoretical stages!! Do you might have any view on my question?
Yes, guess the number of stages and adjust the effciency of your trays to match whatever data you have be it design or operational. If you have no data, get the HETP from the vendor.
Conceptual Sizing Of Adsorber ColumnStarted by Guest_JJvdM_* , 24 Oct 2019 |
Teg Dehydration Stripping ColumnStarted by Guest_SidRah_* , 08 Sep 2025 |
Hybrid Packed And Tray ColumnStarted by Guest_Zulfise_* , 04 Aug 2025 |
Packaging And Gas Velocity In Packed ColumnStarted by Guest_ChemEng_CristianoB_* , 25 Jun 2025 |
