Prime Mover Replacement
8 replies to this topic
#1 Root
Root
  • 293 posts
Posted 01 March 2023 - 05:21 AM
my company planning to replace gas turbine because of maintenance related issues with electric motors for water injection pumps. Pump data is available and Turbines data is not available. I have simulated these pumps in hysys and found power required about 4700 kw.
my question is whether it is worthy to replace gas turbines with electric motors or not and whether vendors have ability to successfully replace the gas turbines or not.
  • 1,634 posts
Posted 01 March 2023 - 07:21 AM
The rotating equipment vendors can give you answers and advice. Locomotive engines are about this size. It sounds like an expensive project with all the electrical infrastructure needed.
#3 latexman
  • 1,893 posts
Posted 01 March 2023 - 07:56 AM
Why would one "replace gas turbines with electric motors", because of "maintenance related issues with electric motors".  That does not make sense.  Please clarify.
If you want a good reply, please take the time and care to state your situation correctly, and thoroughly.  Give as much pertinent detail as you know.  If you are going to hurriedly type in a general question, without review, correction, proper capitalization and punctuation, please just don't bother us.
We cannot read minds.  Who do you think we are?  The Amazing Kreskin?
#4 Bobby Strain
Posted 01 March 2023 - 10:24 AM
That sentence can be read in other ways, too. Try it. Pilesar got it right.
#5 Root
Root
  • 293 posts
Posted 01 March 2023 - 10:38 AM
Lateman, understand your point next time will take care.
Now explain it, as already you understand my question.
#6 latexman
  • 1,893 posts
Posted 01 March 2023 - 11:47 AM
I agree, but lack of punctuation leaves it up to interpretation.  An engineer should know better than to use "text-lish".
#7 latexman
  • 1,893 posts
Posted 01 March 2023 - 03:00 PM
Latexman, understand your point next time will take care.
High reliability and available excess capacity of your power grid could make this an attractive project, but, to be honest, it is big enough in size that it is usually favored by gas turbine economics, especially if the exhaust steam is utilized.  At present, is your exhaust steam utilized effectively?
#8 Root
Root
  • 293 posts
Posted 02 March 2023 - 12:37 AM
No we are not recovering any heat from exhaust gas.
#9 latexman
  • 1,893 posts
Posted 03 March 2023 - 07:11 AM
Then, the answer is not intuitively obvious to me.  "The devil is in the details."  Follow your local data, plans, estimates, quotations, judgement, etc. and may the option with the highest financial return win out!
