Hazardous Area Classification
Posted 25 May 2023 - 02:52 PM
Posted 25 May 2023 - 05:39 PM
Generally speaking, as LT and PS are installed on the body of tank. And the tank is used for storing methanol, both instrument should be ex-proof.
Posted 25 May 2023 - 06:25 PM
Documents attached.
https://www.heatinga...creased-safety/
EDIT:
Don't forget lightning protection.
https://www.methanol...eMethanol-1.pdf
https://oaktrust.lib...93831/Smith.pdf
Hope this is helping you.
Posted 25 May 2023 - 11:20 PM
Depends on fitting. If an instrument has no joints and is connected to equipment sealless (e.g. welded) then this has no potential to ex-fluid release/leak. And vice versa.
Edited by shvet1, 25 May 2023 - 11:21 PM.
Posted 26 May 2023 - 01:09 PM
Edited by nikki-nikki, 26 May 2023 - 01:11 PM.
Posted 26 May 2023 - 01:13 PM
so if they are ex proof..no need to so extent of zone?
Posted 30 May 2023 - 02:54 AM
hi,
An explosion proof zone should be drawn during project phase. And the instrument should be selected according to this document.
I don't mean that there is no need for zone classification. What I want to express is that these instruments should be ex-proofed from my feeling even I have not seen your zone.
Surface Area Calculation For Blowdown Orifice Sizing Including FinnedStarted by Guest_victortheone_* , 17 Feb 2026 |
Storage Tanks Diked Area Fire Protection Using Foam MakerStarted by Guest_mkhattaby_* , 30 Jan 2025 |
Minimum Vapor Disengagement Area For A Kettle BoilerStarted by Guest_Engib33r_* , 17 Oct 2024 |
Ways To Reduce Wetted Surface Area In Psv SizingStarted by Guest_KoreaGyu_* , 21 Aug 2024 |
Diked Area Around Distillation ColumnStarted by Guest_hysyshunter_* , 15 Apr 2024 |
