Can anyone please explain me the nozzle sizing procedure for the Three phase separators ? Inlet and outlet (both liquid and gas outlet) nozzle sizing methods.
Nozzle Sizing In Separators
Posted 30 May 2023 - 02:22 AM
Posted 30 May 2023 - 11:21 AM
Search this forum and you will find lots of information.
Posted 09 June 2023 - 04:14 AM
There are mechanical and process criteria to estimate the nozzle size, mechanical is reliability which allows higher momentum (RhoV2) however the process criteria is different which often takes into account the impact on expected separation e.g. feed nozzle size depend on what other internals are inside the vessel e.g. type of feed device, de-entrainment device etc.
Refer catalogues on vendor websites (Koch Glitsch or Sulzer) for criteria of nozzle momentum as a function of feed device type.
![]() Liquid Liquid Separator SizingStarted by Guest_Kentucky08_* , 03 Apr 2025 |
![]() ![]() Nozzle Sizing CalculationStarted by Guest_BabRafiq1_* , 26 Aug 2022 |
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
![]() Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
Critical Pressure For Choke Valve SizingStarted by Guest_Sherif Morsi_* , 07 Nov 2017 |
