Hi all,
I heard one saying that when sizing flare size, the venting flow rate should be the sum of all PSVs in one fire zone.
Is this right? and where this requirement comes from ? API?
Posted 01 June 2023 - 07:51 AM
Hi all,
Posted 01 June 2023 - 08:58 AM Best Answer
Consider this thread:
https://www.eng-tips....cfm?qid=341580
Hope this is putting you in the right direction.
Posted 01 June 2023 - 10:51 AM
Why have you shown the fire zone as a circle?
Posted 01 June 2023 - 06:15 PM
Thanks, it helps a lot.
Screening Heat & Material Balances Cases For Fire Relief Psv SizinStarted by Guest_powerox6_* , 21 Aug 2026 |
Temp Of Flare Header For Stress AnalysisStarted by Guest_Araboni_* , 20 Jul 2026 |
How To Size A Presure Equalization Line For A 10" Pipeline ValveStarted by Guest_Rerrizftt_* , 14 Jul 2026 |
How To Right Size A Vapor Recovery Unit (Vru)?Started by Guest_MethanolPlant_* , 29 Apr 2024 |
Nitrogen Purge On Flare StackStarted by Guest_sanderson51_* , 08 May 2023 |
