I'm in a process of sizing a PSV located on condensate header of a gas compression plant.
Refer to the attachment to get a clear picture of the process.
Questions:
1) What scenario is applicable to the PSV? Is it gas blow-by case or LCV failure case?
2) If it is gas blow-by case then do we need to consider the inlet separator as high pressure source? Operating pressure = 400psig. Design pressure = 1200psig. Condensate header PSV set pressure = 655psig (defined by client).
what is the definition of high pressure source? Does it corresponds to the 'design pressure'? or is it the 'operating pressure'?
3) Do we need to size PSV for liquid relief and gas relief separately? As per my understanding, in case of gas blow-by the liquid shall exit through PSV first and then the gas. So we need to size PSV for both and then select the worst one.
Experienced thoughts and guidance is required.
