Common Silencer For 2 Psv's
silencer psv vent
#1 Nightwish
Nightwish
  • 14 posts
Posted 25 July 2023 - 05:53 AM
I have 2 PSV's close to each other. Both PSV discharge to atmosphere and each have vent silencer. Is it possible to use 1 commn silencer for both PSV discharges? I have a simple sketch attached.
  • 6,819 posts
Posted 25 July 2023 - 08:01 PM
What is the problem with the existing setup?
To me, NO, you have a risk to affect the operation.
#3 Nightwish
Nightwish
  • 14 posts
Posted 26 July 2023 - 01:33 AM
Thanks Breizh. Actually, the system is not existing. I wonder if its possible to connect 2 PSVs outlets to 1 common silencer. Is there any point that I have to pay attention?
#4 fallah
  • 5,022 posts
Posted 26 July 2023 - 01:35 AM
In general and concerning back pressure standpoint, if two PSVs won't pop up simultaneously appears there would be no problem having common silencer for such two PSVs discharges...
#5 breizh
  • 6,819 posts
Posted 26 July 2023 - 01:48 AM
HI,
You may want to contact these guys to get a definitive answer:
https://www.valvulas...lencers_eng.pdf
I believe a silencer is designed for a specific flowrate (design).
#6 shvet1
shvet1
  • 476 posts
Posted 26 July 2023 - 05:55 AM
Common header/vent is a normal practice if sound engineering has been applied.
Pay attention that in your case superimposed backpressure is variable and depends on built-up backpressure during relief. Balanced design of both PSV is preferred.
Means should be applied to avoid a relief fluid from opened PSV gets to outlet lateral pipe of closed PSV.
