Instrument Air Calculation Based On Strokes Time And Freguency In Gas
9 replies to this topic
#1 keren
keren
  • 5 posts
Posted 04 October 2023 - 06:53 AM
Hello Experts, How Is Instrument Air Calculated For Gas Treatment Systems Based On Strokes? Any Articles Related To Understand This Concept would be much appreciated
Edited by keren, 04 October 2023 - 06:53 AM.
#2 fallah
  • 5,026 posts
Posted 04 October 2023 - 07:06 AM
Strokes in which component?
#3 Pilesar
  • 1,639 posts
Posted 04 October 2023 - 10:18 AM
I am guessing you have a reciprocating compressor supplying air. Each stroke of the compressor piston provides a fixed quantity of air based on the working volume of the compressor cylinder.
#4 Bobby Strain
Posted 04 October 2023 - 12:53 PM
So, now we're  playing 20 guesses?
#5 Pilesar
  • 1,639 posts
Posted 04 October 2023 - 10:11 PM
If 'not knowing' meant 'not speaking' then I would be silent most all the time! I tend to treat many technical questions like a riddle and try to discover what the questioner really wants to know. Just as King Nebuchadnezzar wanted an interpretation for his dream but refused to reveal the dream first, some people struggle with defining a clear scope. I figure that if I state my premise and also the answer then maybe someone will learn something even if it is not what the original questioner wants. I won't play 20 guesses, but it is not much effort to make a guess and then move on. I am not able to imagine another answer that would fit the shadowy parameters of the question. The one skill that would have helped my engineering career the most is the ability to read minds. I sometimes practice it in the hope I will improve.
#6 breizh
  • 6,942 posts
Posted 04 October 2023 - 10:20 PM
Hi Keren,
We need a better description of your system; this will help us to give you a meaningful answer.
More info better answer.
Note: Attached a link to Atlas Copco literature.
https://www.atlascop...-edition-ac.pdf
#7 Bobby Strain
Posted 05 October 2023 - 09:32 AM
Valves stroke, too.
#8 latexman
  • 1,894 posts
Posted 05 October 2023 - 10:26 AM
May I suggest Google before you ask here?  While Googling, based on your findings, modify your search to find the most pertinent information possible.  It may take multiple searches.
#9 Bodhisatya
Bodhisatya
  • 156 posts
Posted 11 October 2023 - 10:21 PM
If this is related to Control Valve and ShutDown UVs , typical rule to thumb is consumption of 2 Nm3/hr IA per stroke from full closed to full open position FOR EACH VALVE.
#10 keren
keren
  • 5 posts
Posted 18 October 2023 - 06:18 AM
Hello, sorry about not being clear on the question. It is indeed  the control valve and shut down valves used in the treatment set up. As such any unit set up that requires instrument air consumption for opening/closing shut down valves and control valves for the matter. I believe In the context of instrument air consumption for valves, "strokes" refer to the number of times a valve actuator moves back and forth to open or close the valve. Each stroke corresponds to one complete cycle of movement.
But thanks for your responses. much appreciate.
Edited by keren, 18 October 2023 - 06:19 AM.
