Blowdown Ro Sizing
13 replies to this topic
#1 T_bag
T_bag
  • 18 posts
Posted 28 December 2023 - 01:37 AM
Hello everyone,
I am currently working on  blowdown line & RO sizing for a gaseous system. The estimated RO size for depressurization to 100 psig is around 0.12 inch (3mm). The upstream and downstream line sizes are 1.5 & 2 inches. I am concerned that RO size of 0.12 is too small. is there any guideline on what minimum RO size to be used.
I am also concerned with the temperature drop due to increased RO size with increase of depressurization rate.
looking for some suggestions.
  • 6,833 posts
Posted 28 December 2023 - 03:03 AM
You may want to use the documents attached .
#3 T_bag
T_bag
  • 18 posts
Posted 28 December 2023 - 03:31 AM
Hi Breizh,
so I am using Unisim for depressurization calculation and reached to a orifice size of 3mm. The doubt I am having, is it acceptable to install a 3mm orifice in a line size of 1.5 inch (38mm).
#4 breizh
  • 6,833 posts
Posted 28 December 2023 - 03:35 AM
How long to depressurize your system?
What is the temperature at the outlet?
Note: I've no clue about Unisim.
#5 T_bag
T_bag
  • 18 posts
Posted 28 December 2023 - 03:58 AM
Case 1:-
Currently I have assumed 10 minute of depressurization to 100 psig. the Beta ratio for the estimated RO is 0.1 (API recommends >0.2).
(Line size :- 40mm (1.5 inch), RO size :- 4mm (0.16 inch)
The downstream RO temperature for current condition is -60 oC.
2.
Case 2:- To main beta ratio of 0.2,
Depressurization time decreased to 3 minutes (RO size :- 0.3 inch (8mm)
Down stream RO temperature :- -84 oC
which case is practically possible.
#6 fallah
  • 5,025 posts
Posted 28 December 2023 - 04:08 AM
Hello everyone,
API recommends a beta ratio of 0.2 or higher...
Edited by fallah, 28 December 2023 - 04:08 AM.
#7 fallah
  • 5,025 posts
Posted 28 December 2023 - 04:15 AM
Case 1:-
2.
Considering low temperature in downstream of RO for both cases, case 2 is highly preferred; because if it's intended the material of downstream RO would be selected based on the reported low temperatures, for both cases the stainless steel pipe should be selected while at least in case 2 the criteria for minimum beta ratio has been met.
#8 breizh
  • 6,833 posts
Posted 28 December 2023 - 07:09 AM
https://bssa.org.uk/...temperatures-2/
To me the depressurization time should be about 15' .
#9 breizh
  • 6,833 posts
Posted 28 December 2023 - 03:52 PM
Did you check with multiple orifices?
Should be easy with your simulator.
#10 snickster
snickster
  • 82 posts
Posted 28 December 2023 - 04:17 PM
Seems like the temperature drop will be the same in any case and not depedent upon the rate of depressurization but only on the ratio of downstream to upstream pressures during depressurization.  The flow will be choked at the orifice throughout the depressurization if downstream pressure is atmospheric or low enough which I believe it is in your case.  The cholked flow critical pressure and temperature will be same throughout regardless of orifice diameter, only thing that changes is the flowrate and therefore time to depressurize.  The flow at orifice pressure and temperature and upstream will vary same but at different rate in my opinion.
#11 T_bag
T_bag
  • 18 posts
Posted 29 December 2023 - 01:20 AM
Hi Breizh,
I did Check.
Increased RO Size leads to lower temperature with lower depressurization rate (around 5 minutes for double RO size to maintain beta ratio of 0.2).
I also consulted with our seniors and I have received the suggestion that lower depressurization time should not be a concern as API suggested time of 15 minutes is the maximum limit.
FYI our system volume is low (35 ft3) .
Edited by T_bag, 29 December 2023 - 01:25 AM.
#12 T_bag
T_bag
  • 18 posts
Posted 29 December 2023 - 01:23 AM
Hi Snickster,
I am surely seeing a lower temperature with higher depressurization rate.
#13 breizh
  • 6,833 posts
Posted 29 December 2023 - 01:32 AM
Yes, the volume is small, less than 1 m3.
Next time supply all the process data, nature of the fluid, P discharge, volume of the system.
#14 katmar
katmar
  • 696 posts
Posted 03 January 2024 - 04:45 AM
The reason API recommend 0.2 as the minimum beta ratio is because the uncertainty in the coefficient of discharge increases for smaller beta values.  If the accuracy of your discharge time is not critical then you can use lower values.  Remember that with a high pressure drop across the orifice the thickness of the plate should be enough to keep the plate from dishing.
