Let's say we have a distillation column which has valve trays.
What does it do to the overall hydraulic performance if we lose one or more valves?
Posted 13 February 2024 - 11:25 PM
Posted 14 February 2024 - 12:37 AM
Globally you will lose one tray, no residence time for the liquid on this particular tray. Will it affect the overall performance of the column? Only you can answer, a simulation can assist.
Posted 14 February 2024 - 06:14 AM
The liquid will drain from that tray through the hole of the missing valve(s). That tray will not have intimate vapor/liquid contact. Vapor from below will flow more. as there is less restriction. As Breizh said, this tray will be useless. The tray below will not get liquid as per it's design. It will not be good, Will it be a mighty issue? Up to you to find out. We have no data.
Posted 14 February 2024 - 10:26 AM
It is rare for such to happen in most services. In those fractionators where it happens, the effect is hardly noticeable.
Posted 14 February 2024 - 09:50 PM
Losing movable valves is very common in some services. Usually missing valves mean corrosion or other problems. Wear and corrosion can make the holes larger so that the valve feet no longer get a purchase on the tray. I have seen columns that have lost a third of their valves as well as whole tray panels without operations noticing any problem great enough for them to shut down and inspect. Compare the performance of movable valve trays to sieve trays. If all the valves were removed, you would be left with a sieve tray.
Organic Peroxide Distillation IssueStarted by Guest_Kimbreaux_* , 19 Feb 2026 |
Short Path Distillation Rotor SpeedStarted by Guest_MEC_* , 11 May 2023 |
Teg Dehydration Stripping ColumnStarted by Guest_SidRah_* , 08 Sep 2025 |
Hybrid Packed And Tray ColumnStarted by Guest_Zulfise_* , 04 Aug 2025 |
Packaging And Gas Velocity In Packed ColumnStarted by Guest_ChemEng_CristianoB_* , 25 Jun 2025 |
