Kettle Reboiler Flow Fractions
kettle reboilers heat exchanger heat transfer flow fractions heat exchanger design
#1 Lyne
Lyne
  • 60 posts
Posted 31 March 2024 - 12:24 PM
Hello everyone,
Is there typical flow fractions for kettle reboilers ? Does the values in Saunders handbook apply to kettle reboilers ? And as per your experience how to adjust these values ?
Thank you
  • 7,058 posts
Posted 31 March 2024 - 10:56 PM
Not sure I understand the query!  flow fraction for Kettle reboiler.  from liquid to Gas 100% minus the residue part W.
Can you share the reference of the handbook?.
#3 Lyne
Lyne
  • 60 posts
Posted 01 April 2024 - 02:17 AM
Attached is the page for your reference, I meant stream flow fractions
#4 breizh
  • 7,058 posts
Posted 01 April 2024 - 02:46 AM
Thanks Lyne,
I cannot support,
wait for others.
Note:
Process heat transfer, Principles, Applications and rules of Thumb by Robert W. Serth and Thomas G. Lestina has a good presentation of reboilers and detailed calculations.
Good luck,
#5 Pilesar
  • 1,695 posts
Posted 01 April 2024 - 07:18 AM
If you are asking how much liquid to withdraw from a kettle reboiler, then that is determined by the distillation column and its required material balance. The kettle reboiler is to be designed for the service required.
#6 breizh
  • 7,058 posts
Posted 03 April 2024 - 04:38 AM
Hi Lyne,
Consider the links underneath:
https://engrmaa.blog...w-fraction.html
https://heat-exchang...d-optimization/
