Rapid Depressurization Of Water
#1 Gole
Gole
  • 12 posts
Posted 31 March 2024 - 11:57 PM
Hello all,
I want to know the most accurate equation that can be used to estimated the temperature difference caused by rapid depressurization of water from for example 100psi_g to 2 psi_g . I am trying to model a liquid liquid ejector, and want to find out the difference in temperature that might be caused at different stages (nozzle, throat, discharge) of the ejector. I have been able to model the flows, velocities and pressures inside excel and want to include the thermal information in it as well. I also would like to thank breizh for recommending the book: Steam Ejectors for the process industries.
Some questions I have while using EOS are, is there any way to model a phase change after the depressurization, is it possible to predict ice formation using any analysis methods?
Thank You.
  • 6,942 posts
Posted 01 April 2024 - 12:14 AM
ice building in steam ejector.
#3 Gole
Gole
  • 12 posts
Posted 01 April 2024 - 01:27 AM
Thank You breizh, also can you provide me with any methods to find temperature of a liquid after its rapid depressurization inside the ejector nozzle?
Thanks.
